Date/Time: Tue, 21 May 2024 06:36:31 +0000
[Programming Help] - showing custom values at order lines
View Count: 657
[2019-10-21 19:43:11] |
ARDAN - Posts: 66 |
I looked at this documentation but I could not find a way to add value to working order lines via my custom study. ACSIL Interface Members - Variables and Arrays Is there a way or what would be your suggestion? I would like to show a precalculated (via my custom study) value next to working (attached) order lines. how can I do this? |
[2019-10-23 12:55:46] |
ARDAN - Posts: 66 |
Dear Support, Do you mind to support me with this? Thanks. |
[2019-10-23 16:56:35] |
There just is not any support for doing this. The closest you can do is draw text on the chart, nearby an order line, using the Text Drawing Tool from ACSIL.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-23 16:56:47
