Date/Time: Tue, 21 May 2024 03:46:27 +0000
High/Low for Time Period - Extended
View Count: 756
[2019-10-21 16:05:51] |
RonW - Posts: 103 |
I want to draw the "Initial Balance", i.e. the Hi/Lo for ES futures from 9:30 to 10:30 Eastern time. It works fine for a day session chart. For a 24 hour chart, I am having this problem: If I want today's line to extend until the new line starts tomorrow at 9:30, it seems I should set "Use Line Stop Time" to Yes and Input a Line Stop Time of 9:29:59. This doesn't work. It doesn't recognize that the time period for which I want to display a line is from 9:30:00 AM one day up to 9:29:59 the next day. Is it possible to make this work? Thanks |
[2019-10-23 05:38:48] |
We are going to change how this study works. The Stop Time will always need to be specified and can be within the same trading day or the next trading day.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-23 05:40:24
[2019-10-23 15:05:44] |
Sawtooth - Posts: 4002 |
The Initial Balance study will do what you want, except it won't extend across the weekend.You can use the Spreadsheet Formula study to fill the weekend gaps. Post again if you want to know the details. |
