Date/Time: Sat, 12 Sep 2026 06:37:07 +0000
Set of Dynamic Bracket Orders
View Count: 1395
| [2019-10-21 15:18:48] |
| Tecomed - Posts: 6 |
Hello Support Team, I have tried Scale-In functionality of Sierra Chart and can't find way to adjust my Bracket Orders according to average price of the position after Scale-In / Scale-Out. Let's go through simple example. I have Scale-In configured and use "SimpleBracket" trading strategy. My chart / DOM is configured to present "Thoretical Average". Let's say, I open Long 1-lot position in ES for 3000.0 with 10-tick stop and 20-tick target bracket orders. So far, so good. I see 3 lines: my position as 1 lot at 3000.0 and 2 bracket orders. After adding 1 more lot at 2998.0 I see my position line moving to 2999.0 and now 2 sets of bracket orders for 1 lot each. Question: Is it possible in Sierra Chart to maintain just 1 set of bracket orders automatically adjusted to number of lots in my current position and average position price with each Scale-In/Scale-Out? Could you please let me know if such functionality exists and how to configure it? |
| [2019-10-22 23:41:10] |
There is no support for this: can't find way to adjust my Bracket Orders according to average price of the position after Scale-In / Scale-Out.
This means you are not using Scale In if you have two sets of bracket orders: and now 2 sets of bracket orders for 1 lot each.
Make sure you have it enabled on the correct Trade Window: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-22 23:41:29
