Date/Time: Tue, 21 May 2024 09:00:38 +0000
Copy chart drawings to other chart; only partially successful
View Count: 642
[2019-10-21 11:39:06] |
User283743 - Posts: 38 |
Please take a look at the screenshots. Could you assist me to make sure all chart drawings are being copied from Chart #4 to Chart#23? As you can see most of the lines are not copied (see arrows); some are...in one instance the text is being copied but not the line. All lines (those that are copied AND those that aren't copied) are drawn using the Ray tool. Settings for footprint chart (#23) are: Copy Chart drawings from Chart: #4 Thank you. http://www.sierrachart.com/image.php?Image=1571657797840.png http://www.sierrachart.com/image.php?Image=1571657909393.png |
[2019-10-22 23:44:20] |
We need to get a simple Chartbook from you which demonstrates this.
