Date/Time: Mon, 03 Feb 2025 00:49:40 +0000
It is possible to put Volume by Price in Chart Region 2?
View Count: 720
[2019-10-21 09:11:50]
GiovanniD - Posts: 41
In this way I would obtain a result similar to the one simulated in the attached image.
Otherwise, is it possible to view the POC on the screen without covering what is drawn below it? (setting a transparency only for the POC or even identifying the Poc in a different way, for example by coloring the text or the only outline of the pink rectangle (of the POC).
Thank's
Piero
imageVBP1.jpg / V - Attached On 2019-10-21 09:11:21 UTC - Size: 178.18 KB - 316 views
[2019-10-21 21:12:28]
First, it is not possible to put a Volume by Price study into a region other than where the Main Price Graph is displayed.
Second, what you are seeing in that image is a Numbers Bars study, not a Volume by Price. With the Numbers Bars study, you can highlight the Point of Control within the bar by having it draw a rectangle around the price value that is displayed at that level. Refer to the following Input for the Numbers Bars for Highlight Point of Control In:
Numbers Bars: Highlight Point Of Control In
The Numbers Bars would give you your best option, but you need to be on Package 5 to be able to use them. Otherwise, there really is not an option that highlights the POC in the way that you are asking.
