Date/Time: Thu, 02 May 2024 01:04:00 +0000
Bracket and OCO orders - where to manage them
View Count: 615
[2019-10-20 03:31:33] |
vish100 - Posts: 111 |
Hi, I have read precious posts on this topic and also tested this my IB paper account. But in general is it better to manage OCO and bracket orders on the IB side or on the SC side? Which side provides more functionality, accuracy and sophitication? thanks |
[2019-10-20 17:30:34] |
You can manage them from either side. There is not going to be any difference but it is easier to do from Sierra Chart if you want to do chart based trading. You would want to enable the server-side bracket order option: Global Trade Settings Windows: Use Server Side Bracket Orders (if supported) (Global Settings >> General Trade Settings >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
