Date/Time: Thu, 02 May 2024 12:47:06 +0000
Quote spreadsheet
View Count: 843
[2019-10-19 08:08:20] |
User495158 - Posts: 106 |
Is it possible to save quote spreadsheet with headings and scrollbars turned off and not to have them turn off manually each time the spreadsheet is opened? Thanks |
[2019-10-19 11:46:41] |
We will look into this.
