Date/Time: Thu, 02 May 2024 12:40:01 +0000
Advance Decline Line Shows Wrong
View Count: 573
[2019-10-19 06:21:40] |
User751809 - Posts: 1 |
Hi, My Advance Decline Line is showing up weird as crunched up like in attached screenshot. How to fix this? |
Screenshot_217.jpg / V - Attached On 2019-10-19 06:20:05 UTC - Size: 143.14 KB - 464 views Attachment Deleted. |
[2019-10-19 18:01:23] |
We are quite sure that result is all mathematically correct. We do not see any problem with the underlying market data feed at that time for those days. If you look at the components and do the math you will see that the calculation is correct. Refer to: Sierra Chart Market Statistics: Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
