Date/Time: Mon, 03 Feb 2025 00:55:10 +0000
CME live data/depth free trial?
View Count: 1018
[2019-10-18 17:12:12] |
GreegT - Posts: 23 |
Hello, is this possible somehow with another provider/broker? Also is there an updated list of all the futures live data providers that SC currently supports? Thanks |
[2019-10-18 18:55:13] |
Really we strongly strongly recommend just waiting for our delayed CME data feed we are going to be having out in a couple of weeks.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-18 18:55:22
[2019-10-20 16:23:58] |
Can I use basically any futures broker with SC for order placement? Also is this list of CME data providers updated or are there more? Is Historical and Real-time Futures Data Included?: Is Historical and Real-time Futures Data Included? Thanks for the response. |
[2019-10-22 22:50:27] |
No that is not the case. You can find a list of supported brokers here: https://www.sierrachart.com/index.php?page=doc/OtherSitesLinks.php#Brokers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
