Date/Time: Thu, 02 May 2024 10:25:40 +0000
Order fill lines mismatch
View Count: 1104
[2019-10-18 16:43:09] |
joshtrader - Posts: 439 |
I am running two instances of SC. In the primary one, my Net PL is correct. In the second one, it is incorrect, and the order fill lines drawn on the chart are wrong. For example, executions which open a new position are marked as closing an old one. How do I synchronize this? I use CQG and have done a "refresh with service". The Trade activity log in the second instance also shows correct Open/Close behavior. So, I'm not sure why the lines on this chart are mismatched, and why the NPL in this chart is incorrect. Any ideas?
[2019-10-18 16:50:31] |
Refer to: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities (Accurate Entry/Exit State, Fill Matching and Position Quantities) And: Help With Daily Profit/Loss Value We recommend using this service instead of CQG for proper order fills: Sierra Chart / Trading Technologies Futures Order Routing Service We will not be providing further support here in relation to CQG.. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-18 17:07:27
