Date/Time: Sun, 02 Feb 2025 22:56:58 +0000
footprint numbers don't match live webinar
View Count: 614
[2019-10-18 16:06:06]
User389151 - Posts: 37
Anyone know why the footprint numbers are different than my live webinar? See attached
my footprint and heatmap is on left, webinar's footprint and heatmap is on right. footprint numbers don't match
is it because I didn't purchase the denali exhange service?
thanks
imagecomparison.JPG / V - Attached On 2019-10-18 16:03:53 UTC - Size: 207.73 KB - 380 views
[2019-10-18 16:11:13]
What is on the left is going to be correct because you are using the Sierra Chart Exchange Data Feed which is the same as the Denali Exchange data feed. On the right is the CQG data feed.
So you are fine. Just make sure you have a tick by tick data configuration:
