Date/Time: Thu, 02 May 2024 11:57:59 +0000
DOM CHART Width
View Count: 1069
[2019-10-18 14:01:22] |
User748886 - Posts: 1 |
How can you reduce the width of the DOM on the chart? I send you a print screen where I have marked the area I want to reduce to the maximum because it takes up unnecessary space.
Attachment Deleted. Screenshot at Oct 18 09-54-59.png / V - Attached On 2019-10-18 13:58:16 UTC - Size: 192.88 KB - 331 views |
[2019-10-18 18:44:04] |
Yes to some extent. This is documented here: Global Trade Settings Windows: Chart/Trade DOM Column Widths and Headers (Trade >> Customize Chart/Trade DOM Columns) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
