Date/Time: Tue, 15 Sep 2026 05:58:24 +0000
Limit chase for entry but not for exit?
View Count: 945
[2019-10-18 06:39:30]
ycomp - Posts: 334
I am using Chart Trader on the DOM
I enter via keyboard shortcuts I have defined.
I use Limit Chase orders (Chart Trader / Menu / Orders / Use Limit Chase Orders)
So the entry is fine... I get a limit chase depending when I enter.
However, if I click on the DOM to set a limit for exit - it is also a limit chase. And I would like it to be a plain limit order.
So is there a way to either enter a plain limit by clicking on the DOM or via a keyboard shortcut?
or is there a way to remove the chase once the order is visible on the DOM ?
[2019-10-18 07:42:59]
This really is an older option and we recommend disabling it:
The way to specify order types Is directly through the Chart DOM settings:
Global Trade Settings Windows: Chart DOM Settings
The way that you should handle your exits is through Attached Orders and then specify a Limit Chase order as the Target order:
Attached Orders
You can also use custom keyboard shortcuts and do any order type that you like:
Basic Trading and the Trade Window: Custom Trading Keyboard Shortcuts
