Date/Time: Thu, 02 May 2024 09:42:16 +0000
Extend bar value to future intersection not updating on chart
View Count: 490
[2019-10-18 05:35:03] |
User392279 - Posts: 67 |
Hi, Extend bar value to future intersection not updating on chart. Need to reload the study then it updates. I'm using it for VBP POC extension. Can you please fix this issue? Thanks. Date Time Of Last Edit: 2019-10-18 05:39:50
[2019-10-21 05:48:33] |
It sounds like you are doing something which is unsupported. What do you mean by this: I'm using it for VBP POC extension.
How did you accomplish this? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
