Date/Time: Sun, 02 Feb 2025 23:08:56 +0000
Problem with Chart Replay - it's processing ACSIL-set orders after PAUSE ONLY
View Count: 658
[2019-10-17 23:48:43] |
User300921 - Posts: 7 |
Problem with Chart Replay - it's processing certain ACSIL-set orders after PAUSE ONLY I've created a special "cut-off" version of this test trading system which should allow you to see the problem Tested it on both PC's - different compilers [yours remove & Visual Studio 2017], 32 & 64 versions, all the same Note: seems work relatively OK if NOT on chart replay mode NOTE1: it was working well about a year ago [last time I've tested something like that; and I'm trying re-test something else in Chart Replay mode right now - but I can't] NOTE2: I'm trying to add ACSIL (CPP) file with chart settings (cES.cht ) - but somehow I can't; "ADD / Edit Attached Files" button does nothing Date Time Of Last Edit: 2019-10-17 23:52:28
No_pause=another_set_of_orders_ONLY_after_11am.png / V - Attached On 2019-10-17 23:47:21 UTC - Size: 107.98 KB - 275 views Paused_here.png / V - Attached On 2019-10-17 23:47:42 UTC - Size: 101.72 KB - 276 views SC64_settings.png / V - Attached On 2019-10-17 23:47:52 UTC - Size: 156.53 KB - 257 views |
[2019-10-17 23:58:40] |
NOTE3: added files in a separate message because of "Error: No file was uploaded. Attachment Limit Reached." NOTE4: tried "Accurate Trading System Back Test Mode" - same results; no difference in order processing. |
Private File Private File Attachment Deleted. |
[2019-10-18 11:34:16] |
NOTE5: looks like we've found it; problem seems in order placement logic when trying to place orders in opposite directions simultaneously.
