Date/Time: Tue, 30 Apr 2024 09:23:19 +0000
data not accurate for US2000
View Count: 1080
[2019-10-17 01:20:36] |
User686802 - Posts: 69 |
Hi,I did search on Support board but nothing about the US2000 which gives numbers not anywhere near the Russell 2000 index nor the futures. For example, today, index and December futures close is around 1524 but US2000 shows close at 1495. Something isn't correct about US2000.
[2019-10-17 06:41:51] |
This is not anything we can help with, this is CFD data from FXCM.
