Date/Time: Fri, 17 May 2024 19:48:38 +0000
Sierra Chart Exchange Data Feed
View Count: 753
[2019-10-16 23:37:39] |
User987654 - Posts: 65 |
Hi, I just want to clarify how the SC Exchange Data Feed works. I currently have an IB account that is subscribed to CME data and I am not using SC. If I sign up for SC package 3 and add the SC Exchange Data Feed and add Full CME Group can I cancel my CME data subscription at IB or do I need to maintain both in order to have access to real time data. I plan to execute my trades using IB API through SC. I've searched the board but I couldn't find this exact question. Thanks |
[2019-10-17 10:24:49] |
We have a new data feed for CME data and it is this one: Denali Exchange Data Feed This is the one you want to use. can I cancel my CME data subscription at IB Yes you can but you will no longer have the real-time futures data within TWS.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-17 10:25:00
[2019-10-19 00:27:06] |
I read through the documentation but I don't see Interactive Brokers as a supported clearing firm. If I can not route orders using TT to Interactive Brokers, will I be able to send orders through SC? |
[2019-10-19 11:46:21] |
Interactive Brokers is fully supported: Interactive Brokers Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-23 07:15:11] |
Marc@SC - Posts: 13 |
But order routing via TT does not work - right? IB is not in the list in the field Clearing Firm Name: https://www.sierrachart.com/UserControlPanel.php?page=SCOrderRoutingServiceTradingAccountAssignmentRequestForm |
[2019-10-23 07:17:14] |
If you are using Interactive Brokers you cannot use the TT order routing.
