Date/Time: Tue, 30 Apr 2024 12:04:36 +0000
[User Discussion] - Extend line until to EOD
View Count: 694
[2019-10-16 22:27:27] |
Crtfyd - Posts: 277 |
FYI. On something like the "Color based on Alert Condition" Study. If I use the "Draw Extension Lines at Color Bar" and set it to the newly added "Extend to End of Day". Then I check "Value Label", it will NOT show when out of view of the triggered time on the graph. If Extend to "End of Chart" is checked, it will. So I think its possible. It defeats the purpose of the extended line later in the day without seeing the value quickly (as opposed to checking it via the crosshairs). Suggestion to fix on future versions unless I'm missing something. Thx. |
