Date/Time: Tue, 30 Apr 2024 14:03:22 +0000
FCM change
View Count: 564
[2019-10-16 20:31:40] |
User221057 - Posts: 12 |
Good afternoon. Couldn't help I changed FCM from Phillip Capital to IRONBEAM.What do I need to do that it is normal to go to a new account with a new password |
[2019-10-16 20:59:15] |
Through Ironbeam, will they be putting your trading account on the CQG system? You will continue to use your same Sierra Chart account, no changes are needed with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-16 21:02:36] |
Yes, everything is correct connection will be through CQG
[2019-10-16 21:06:28] |
Therefore, follow the instructions here to connect Sierra Chart to CQG: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-16 21:10:46] |
Thank you very much
