Date/Time: Tue, 30 Apr 2024 08:19:59 +0000
Using Sierra Chart Data in IB TWS
View Count: 542
[2019-10-16 17:51:00] |
Adam Schwartz - Posts: 81 |
Hi, I have just subscribed to SC real time data and have integrated it to trading service through Interactive Brokers. The documents you provided were helpful. All I intend to do is to view SC real time data through the TWS platform. Is this possible? If so, how? I cannot seem to find any documentation to have SC data in the TWS platform. Thanks in advance for your help. |
[2019-10-16 21:35:54] |
You can only use the Sierra Chart market data within Sierra Chart. Not within Trader Workstation.
