Date/Time: Tue, 30 Apr 2024 11:13:03 +0000
Missing attached stop fill after reconnecting to IB API
View Count: 551
[2019-10-16 16:35:21] |
tomas262 - Posts: 135 |
TWS platform restarted but could not login properly right away. I logged manually later in the morning but Sierra does not show that the stop order was filled. Position size is correct only order fill is not counted. Do I have to add the fill manually or is there any other way? To be honest I have traded with many brokers with no issues at all but all this IB / TWS / API thing is kind of frozen since Gordon Gekko times :-D Date Time Of Last Edit: 2019-10-16 16:38:08
[2019-10-16 21:33:49] |
In regards to this, refer to: Trade Activity Log: Missing Order Fills from Trade Activity Log If you are trading futures, have a look at this service, which maintains long-term order fill history with no difficulties related to that: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
