Date/Time: Tue, 30 Apr 2024 09:14:33 +0000
Can I change the colour here please
View Count: 631
[2019-10-15 22:58:18] |
Mark Sear - Posts: 42 |
Hi. Can I change the colour of the arrowed text box please. Its the price as indicated by the crosshairs. I dont like white on black as it is hard to read. Can I change it please? I cannot see where this setting is. Thanks.
Greenshot 2019-10-15 23.56.09.png / V - Attached On 2019-10-15 22:56:36 UTC - Size: 24.92 KB - 270 views Attachment Deleted. |
[2019-10-16 05:35:47] |
Ackin - Posts: 1865 |
Try this: 1) select Menu >> Chart >> Graphics Settings - Chart 2) unselect the option for Use Global Graphics Settings Instead Of These Settings 3) Menu >> Graphics Settings - chart >> Chart Values: Color of the Price and Time Boxes Graphics Settings: Chart Values: Color of the Price and Time Boxes Date Time Of Last Edit: 2019-10-16 05:42:15
[2019-10-16 23:15:53] |
Note that by unselecting the option for Use Global Graphics Settings Instead of These Settings will make the changes only for the current chart and not for all charts. If you want to make the change for all charts, leave that option selected and instead go to Global Settings >> Graphics Settings and change the colors there. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
