Date/Time: Tue, 30 Apr 2024 08:55:33 +0000
trade DAX futures
View Count: 1429
[2019-10-15 09:30:06] |
user - Posts: 77 |
If i want to trade DAX futures, without using the market depth, do I need to subscribe any datafeed?
[2019-10-15 09:58:31] |
user - Posts: 77 |
DAX @ DTB
[2019-10-15 12:41:34] |
You definitely need a data feed but we see you are using Interactive Brokers so you can obtain the data feed through them. Refer to: Interactive Brokers Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-15 13:27:55] |
user - Posts: 77 |
i cant just subscribe through sierra?
[2019-10-15 21:50:33] |
Yes you can obtain the EUREX data through the Sierra Chart Exchange Data Feed. You can activate the EUREX exchange here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-16 00:09:19] |
user - Posts: 77 |
1. what is the difference between subscribe through sierra and through ib? why sierra is much expensive? 2. Actually I just want the real time bid ask volume data, which one should I choose? 3. Even I dont subscribe Eurex now, I can see the real time (not delayed) chart. Is the chart displaying the right data? |
[2019-10-16 21:43:03] |
1. Not within the scope of our support. 2. You will need to activate the EUREX exchange here for this: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures 3. Would not be fully accurate when using Interactive Brokers data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-16 21:43:09
[2019-10-17 02:08:09] |
user - Posts: 77 |
Thanks so much! Regarding the real time bid/ask volume data, would there be any difference if I subscribe ib or sierra's? |
[2019-10-17 10:57:50] |
Yes there would be a difference. We recommend using the Sierra Chart Exchange Data Feed for this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-17 10:58:00
