Date/Time: Sun, 02 Feb 2025 22:00:17 +0000
DTC Bridge crashes when connecting to Rithmic Singapore Paper Trading Server
View Count: 647
[2019-10-15 01:18:20] |
dpotvin - Posts: 1 |
Hello, each time I try connecting to Rithmic Paper trading server in Singapore, DTC crashes on me and never connects. This never happens when connecting to the normal paper trading server. Attached are the Rithmic logs. Thanks in advance - Dave |
Private File |
[2019-10-15 07:17:12] |
This is going to be a problem with the Rithmic software and we cannot help with this. Also refer to: Technical Help for Rithmic is Now Discontinued as of December 1, 2019. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-15 07:17:20
