Date/Time: Fri, 11 Sep 2026 04:02:46 +0000
Selectively Assign Stop/Triggered Stop
View Count: 842
[2019-10-15 01:05:03]
D Branch - Posts: 5
Dear Support:
I trade with hotkeys. I have four hotkeys assigned:
9 key: Buy Market
0 key: Sell Market
7 key: Sell (Short) Market
8 key: Buy (To Cover) Market
I want to assign a stop or triggered stop (not sure on terminology) to the 9 and 7 keys, so that if I open the order and the price immediately moves against me (by 2 ticks) a stop will be triggered and I will automatically exit the position at market.
Since I want to manually take profit (with 0 and 8 keys), I do not want the stop (2 ticks) applied to the 0 and 8 keys. (I would like the 0 and 8 keys to be simple: Sell and Buy at market only.)
How can I do this? And is this technically called a Stop or Triggered Stop? Do I need both Stop and Triggered Stop set to an offset of 2 ticks on the "Targets" tab of the "Chart Trade Window"?
Thank you in advance!
[2019-10-15 11:36:09]
This is not supported. But all you need to do is just make sure to disable the Use Attached Orders option on the Trade Window which you can set up a shortcut key for, when you do not want to have the attached Stop.
For the attached Stop order what you want to use is Attached Orders:
Attached Orders
You can use whatever Stop order type that you want.
Date Time Of Last Edit: 2019-10-15 11:36:31
