Date/Time: Sun, 02 Feb 2025 21:52:55 +0000
TD Ameritrade Futures
View Count: 578
[2019-10-14 21:03:40] |
dav!d - Posts: 2 |
I am having a problem with TD Ameritrade. When I open a intraday chart for ESZ19 the data is downloaded and the chart displays correctly, however it never updates until I close SC and reopen. after the data is downloaded the titlebar change's to "Symbol not found". I am not having any problems viewing other symbols, just futures. |
[2019-10-15 12:03:28] |
Refer to: Is Historical and Real-time Futures Data Included? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
