Date/Time: Sun, 02 Feb 2025 21:47:17 +0000
Can't find the settings described in documentation
View Count: 607
[2019-10-14 20:42:16]
User164131 - Posts: 19
In Chart Settings on the "Advanced Settings 3" tab there is no "Extend Chart DOM Across Entire Chart When Using Ctrl/Alt" function described here — Chart Settings: Extend Chart DOM Across Entire Chart When Using Ctrl(Buy) / Shift(Sell) (Chart >> Chart Settings >> Trading menu)
imageScreenshot (125).png / V - Attached On 2019-10-14 20:37:34 UTC - Size: 53.93 KB - 267 views
[2019-10-15 12:02:22]
You need to update to the current version of Sierra Chart:
