Date/Time: Sun, 24 Nov 2024 23:09:50 +0000
subgraph in numbers bars calculated values
View Count: 1259
[2013-12-17 11:33:01]
User26059 - Posts: 19
If I wanted to have a column in bars calculated values of numbers bars that subtracts the delta from the cumulative delta what would I do? Where would I start?
Thanks for the help
Date Time Of Last Edit: 2013-12-17 17:55:27
[2013-12-18 01:46:43]
Did you want the result displayed as numbers? Or as a graph.
[2013-12-18 04:42:56]
As Numbers Please!
Date Time Of Last Edit: 2013-12-18 14:58:58
[2013-12-20 20:44:12]
Something like this will have to be custom programmed. We probably can do it for you for about 45 USD which will only be part of the cost.
We will have to get back to you on this next week.
