Date/Time: Fri, 21 Feb 2025 18:05:45 +0000
Level II using IQFeed working?
View Count: 872
[2019-10-14 14:16:02] |
User871996 - Posts: 3 |
I am comparing SC with Ninja. I have IQFeed with NASDAQ L2/OpenView. I can see L2 on Ninja. How can I see L2 in SC? Thank You |
[2019-10-14 16:32:35] |
Stock level 2 data from IQ Feed is not supported in Sierra Chart. However, the IQ Feed software installed on your system, does have an application to view this. You can access it from the right-click menu on the IQ Feed icon on your system tray.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-14 16:33:08
[2021-01-20 10:10:55] |
Nkrastins - Posts: 35 |
Hello, can you please clarify a bit more about this? as I can see at the bottom of this document L2 is kinda supported for stocks DTN IQ Feed Data Service However, when I want to see those limit orders in my DOM, I only see the best BID/ASK. Thanks Date Time Of Last Edit: 2021-01-20 10:11:22
[2021-01-20 13:36:26] |
Our answer is the same as post #2: Stock level 2 data from IQ Feed is not supported in Sierra Chart. However, the IQ Feed software installed on your system, does have an application to view this. You can access it from the right-click menu on the IQ Feed icon on your system tray.
Please be aware we are going to be offering a new NASDAQ data feed with level 2 data we expect in the second quarter of this year. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-20 13:36:59
[2021-01-20 19:25:36] |
Perfect, looking forward to that! How much approximately will be the price, some $50-60/mo? Do you also consider offering TotalView (L3) as well? Thanks |
[2021-01-21 02:05:38] |
We have not yet worked out pricing but it will not be that high. The data feed we are getting from NASDAQ as we understand is the TotalView data feed.
