Date/Time: Thu, 04 Jun 2026 06:15:44 +0000
How to connect two lines?
View Count: 937
[2019-10-14 11:54:03]
SWilk - Posts: 11
Sierra chart is great but I am missing something. Is there a possibility to connect two lines together and move them as 1 whole (on screen angle tool) like the software below.
http://www.iconico.com/protractor/
Best regards
Silas Wilk
[2019-10-14 12:11:29]
You could use the Triangle drawing tool but then that's going to give you three lines.
[2019-10-14 12:17:35]
SWilk - Posts: 11
Thank you for the fast response. Dont think you understand what i mean. I need to be able to move it with a fixed angle. With the triangle drawing tool it only makes a triangle but whenever you take one line it doenst move the other one aswell. I need to be connected and move together as one element with for example 60% angle
[2019-10-14 20:28:10]
You can certainly move a Triangle drawing as one complete unit. Just initiate a move from the middle of one of the lines.
