Date/Time: Sun, 02 Feb 2025 21:53:29 +0000
Symbol Specific Chart and Study Settings
View Count: 548
[2019-10-14 11:43:59] |
ticinotrader - Posts: 401 |
Dear Support, Can you please let me know if it is possible (or you plan to implement) to store chart and study settings linked to a given symbol? Similar to how chart drawings can be stored on a symbol-by-symbol level. I am usually switching through a longer list of instruments one by one, and although most of my tasks can be done with uniform settings, there are tasks that require adjusting chart parameters (session times, volume multipliers, certain study settings, etc) that can be quite complex task if always done manually one-by-one. Because of the high number of instruments, maintaining separate chartbooks for each instruments is not the best solution either (although this is the way I use). Any advice/comment would be highly appreciated. Thank you! |
[2019-10-14 12:33:38] |
No this is not supported or planned. But there are global Symbol Settings you can set per symbol and those will be applied when you change the symbol of the chart: Global Symbol Settings Be sure to enable the option to apply the Session Times when the symbol of the chart is changed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-14 12:35:38
