Date/Time: Sun, 02 Feb 2025 23:45:17 +0000
Volume profile
View Count: 1165
[2019-10-14 10:10:07] |
User599466 - Posts: 9 |
Hello I have now set of a volume by price study on my chart. I have it set to all bars on chart and I have it right aligned. I can't seem to find any instruction about how to change the width of it. Is that possible to do using the key board? So that it is not spread out so far over my chart? I would also like to make the outline of the profile black and the colour within the profile like a heatmap so I can easily see the lowest volume areas etc. Is that possible? I have read through all the notes and can't seem to see how I do this. Apologies if its in there and I've missed it. If it is, can you maybe direct me to the specific sections? thanks Martin |
[2019-10-15 18:05:21] |
John - SC Support - Posts: 37656 |
In order to change the width of the Volume by Price profile, refer to the following Input and the one below it: Volume By Price Study: Maximum Volume Bar Width Type To change the outline of the profile, refer to the following and also note the item 2 below it for the Evening Session: Volume By Price Study: Volume Bars Outline and Fill Colors (SG8) To display the coloring as a heatmap, refer to the following Input: Volume By Price Study: Color Code Volume Bars Based on Percentage of POC For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
