Date/Time: Sun, 02 Feb 2025 21:55:07 +0000
Developing year high/low
View Count: 627
[2019-10-14 04:50:54] |
User3847 - Posts: 8 |
Is there a way to get the developing year/month/week high/low? This is different from using the Period OHLC-Variable Period study, which takes the year high low and copies the value backwards to the beginning of the year. I want the year high/low as it was known up to the current bar, not in the future. This is possible intraday, but I can't find a way for year/month/week high lows. Thanks.
[2019-10-15 11:40:11] |
We will add this capability to the Period OHLC-Variable Period study.
