Date/Time: Thu, 02 May 2024 03:56:50 +0000
Where did my price labels go?
View Count: 926
[2019-10-13 21:06:04] |
User703334 - Posts: 59 |
I updated to latest version today and suddenly lost my price labels for my extend rectangles. They are double extended rectangles which used to show price labels on the left edge of the window. I don't want price labels to appear on the right, as they interfere with price action and provide more clutter. How do I get (double extended) Extended Rectangles back with price labels?? Same question applies any drawing that's fully extended. Thank you, |
[2019-10-14 09:50:34] |
We see no problem with this. Check the Properties for the drawing and make sure the Show Price Labels option is enabled as well as the related options are set as you need: Chart Drawing Tools: Drawing Tool Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-14 09:51:16
[2019-10-14 17:13:16] |
I triple checked and all options are as they're supposed to be. Funny thing is I'm not having the same issue on other charts. Just this one in particular. Do I have to delete it and rebuild it? Or, what would you recommend to be least burdensome?
[2019-10-15 11:33:20] |
Does not make sense to us. What if you add a new Extending Rectangle drawing. Do you notice a problem with the labels with that?
[2019-10-16 00:22:40] |
Found the problem. My window was slid just far enough left to hide the price labels...had no idea. Sorry.
