Date/Time: Sun, 02 Feb 2025 21:56:30 +0000
transact trading
View Count: 825
[2019-10-13 15:06:14] |
User462190 - Posts: 2 |
when setting trade data I only have transact ws as a choice not transact trading. transact ws just gives me error message. How do I get transact trading back on my trading option list?
[2019-10-13 15:41:14] |
Most likely you are getting the error described here: https://www.sierrachart.com/index.php?page=doc/TransAct.php#AccountLogonError (Account Logon Error) The solution to the problem is explained in that section. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-13 15:41:54
