Date/Time: Sun, 24 Nov 2024 23:00:22 +0000
Tool Text - DT_LEFT
View Count: 1603
[2013-12-17 06:53:16]
ejtrader - Posts: 688
Hello SC Team - Have couple of questions related to TOOL_TEXT.
Question 1 - I am trying to draw some text Left to a certain BarIndex using the option - DT_LEFT - but doesn't seem to work ( DT_RIGHT works or so it appears . Is this option available for TOOL_TEXT? With DT_LEFT - Would expect the last character of the text to be "left" of the bar index picked but it's not working as intended.
Question 2 - Is there any option to Attach the text to the Price scale separator similar to the attached chart? At present I can do it using "sub-graph" and turning on the text. Would like to do it using TOOL_TEXT if it is an option. With Sub-graph based text - Irrespective of the horizontal scale - the text gets perfectly attached to the price scale and wanted to see if something similar can be done using TOOL_TEXT.
Question 3 - Is it possible to highlight the price in Pricescale through Tools similar to the one you highlight using "last Price marker"?
PS: Have explored the GDI route earlier but being handicapped due to "sc" structure not being available to GDI functions and trying to use TOOL_TEXT instead.
Date Time Of Last Edit: 2013-12-17 15:54:49
imagesc_Text_Alignment.jpg / V - Attached On 2013-12-17 06:54:19 UTC - Size: 8.18 KB - 498 views
imagesc_text_alignment2.jpg / V - Attached On 2013-12-17 15:53:48 UTC - Size: 39.32 KB - 475 views
[2013-12-19 17:27:47]
SC Team - At present you use LL_* options for subgraphs. Wondering if there are any equivalent options for Tools(as long as the tool value is rounded to the price).
LL_VALUE_ALIGN_VALUES_SCALE
LL_NAME_ALIGN_LEFT
LL_NAME_ALIGN_RIGHT
