Date/Time: Tue, 21 May 2024 10:51:09 +0000
Stop
View Count: 721
[2019-10-11 22:01:44] |
John Ara - Posts: 125 |
Please let me know how I may set a new child stop order after my parent stop order gets filled. Thank you. |
[2019-10-14 09:47:09] |
You just need to submit a new Stop order. This can be a simple independent Stop order or you could use this Order Type: Order Types: Send Attached Orders - Position/Price Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-14 12:15:48] |
Actually I need to know if there is a way to set parent and child orders all at once. In other words, I want to set my child order before parent order gets filled so as soon as parent order gets filled, child order shows up. Thank you. |
[2019-10-18 18:49:45] |
Yes of course. This is fully supported through Attached Orders: Attached Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-18 18:50:04
[2019-10-24 20:04:56] |
It still leaves stops before main order gets filled. Your response is too general, Please refer me to specific place to set my child orders to show up after parent order gets filled. Thank you. |
[2019-10-24 22:19:59] |
Refer to: Attached Orders: Hiding Attached Orders on Chart Until Parent Fill Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
