Date/Time: Sun, 02 Feb 2025 22:10:25 +0000
What data selection should I make to upgrade to real time?
View Count: 765
[2019-10-11 20:39:23] |
TraderTen - Posts: 80 |
I now have your Historical data package. Would going to Dinalli be the best way to accomplish that?
[2019-10-12 21:33:07] |
It just depends on what exchanges you want Real-Time data for. If you only want data from the CME Group of Exchanges, then the Denali Exchange Data Feed is the best selection. Otherwise, if you need data from other exchanges (like Eurex, or NYSE), then you would need to use the Sierra Chart Exchange Data feed. This is all explained here: Real-Time Exchange Data Feeds Available From Sierra Chart: Introduction Also be aware of: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-13 08:16:16
