Date/Time: Sun, 13 Sep 2026 04:25:47 +0000
Few Questions, for pair chart
View Count: 1099
| [2019-10-11 20:26:19] |
| Prakash Saurabh - Posts: 1 |
Hi I was wondering if I can utilize the charts to get the realtime pairs trading data. I use TOS, however I do not get the charts as fast as what I want. Maybe I can use this. Can you give me a call at (see acct info for phone number) to discuss. Thanks, Prakash |
| [2019-10-12 05:35:08] |
What exactly do you mean by " realtime pairs trading data. "? We need specific details and symbols.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-12 05:35:24
| [2019-10-17 23:00:15] |
| John - SC Support - Posts: 47854 |
From customer: I wanted to basically understand whether the price on the chart changes immediately tick by tick, or is it refreshed after certain time. In TOS, I can see the price move in the charts after every second or so.
I want to do this to trade pairs like SPY -QQQ. While there is an ability to stop price the pair, I do not get the price which TOS chart shows, because the price has moved. I was wondering if with sierra chart I get almost realtime price, which moves continuously then I can pair trade better. I want to do short term frequent pair trades. That is why continuously changing price is important to me. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-17 23:00:46
| [2019-10-20 23:05:43] |
The Chart Update Interval is adjustable: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) And you can create charts using any custom formula. Refer to: Custom Calculated Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-20 23:06:27
