Date/Time: Sun, 02 Feb 2025 21:37:01 +0000
stop automatically cancel
View Count: 751
[2019-10-11 11:27:14] |
SkyKeeper - Posts: 40 |
How to make the stop automatically cancel if the counter limit has worked?
[2019-10-11 14:03:51] |
Mack - Posts: 83 |
Make sure you have "Use Attached Orders" enabled. (check "Targets", if there is a stop and limit order in your targets, they will be part of the same bracket). Then it works like you want it. If you just manually add stops to a position, they will not be part of that bracket, or OCO set. Attached Orders |
[2019-10-11 14:48:21] |
Yes included. Nevertheless, if I set a counter limit and it works, then there are two stop orders. 1. from my position 2. from the triggered limit
[2019-10-11 18:22:16] |
You did not add a Target order to the Attached Orders. This is essential: Attached Orders: Using Attached Orders and Attached Order Settings Also refer to the information here on Order Cancels Order (OCO) groups: Attached Orders: OCO Group (Group) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-27 19:44:37
