Date/Time: Wed, 01 Jan 2025 13:39:15 +0000
Trade Activity Window/Direction Trades Are Sorted
View Count: 1013
[2013-12-16 22:24:40] |
Luke - Posts: 142 |
can the trade activities in the "trade activity log" somehow be sorted in opposite direction, so that the last activity is always first in the list? otherwise you have to keep scrolling down to read each new entry as soon as the window is filled up with entries. clicking on "date time" to change the direction of sorting doesn´t work. in the "orders and positions" window you can just click on any tab to change the direction the entries are sorted, it would be nice to have this option here too.
[2013-12-18 10:34:02] |
Luke - Posts: 142 |
no solution? this is a serious problem, if you´re daytrading you just don´t have the time for constantly scrolling down to check your executions, you want to have them right in front of you.
[2013-12-18 14:53:28] |
Luke - Posts: 142 |
ok i found a solution, when the window is filled with trades, you can adjust the displayed data range, so that the older trades aren´t visible. but it would still be nice to have the option of changing sorting direction, as in the trades orders and positions window.
Date Time Of Last Edit: 2013-12-18 15:32:11
[2013-12-18 18:09:16] |
Sorting by time is something that we plan to add to the Trade Activity Log. If you select the very last line of the Trade Activity tab, as new lines are added, they will automatically scroll into view.
[2013-12-18 20:20:58] |
Luke - Posts: 142 |
ok thanks, that works!
[2013-12-18 21:00:43] |
Actually to be more clear, when we say sorting by time, what we meant is the ability to change the display order from ascending by time to descending by time.
[2013-12-18 22:12:55] |
Luke - Posts: 142 |
yes, you already have that ability in the "orders and positions" window, would be great to have it in the "trade activity log" too. |
[2016-05-25 02:47:06] |
sigmadict - Posts: 95 |
EDIT - Descending Display Order in the trade activity log does not work for me, it is gray and I can't make it available. Any idea how to make it work ? Thanks Regards |
[2016-05-25 03:01:47] |
This only works on the first tab (Trade Activity) of the Trade Activity Log window.
[2016-05-25 16:39:40] |
Could you make it available to the Trades Tab please, it will be as useful as the Trade Activity. It's a great value to access your last trades in descending order and quickly see what's going on with your trading. It would be much appreciated. Thanks Regards |
