Date/Time: Sun, 02 Feb 2025 22:10:10 +0000
sc.ScrollToDateTime with custom chart / TPO Profile
View Count: 628
[2019-10-10 23:28:13] |
onnb - Posts: 662 |
We are using sc.ScrollToDateTime in a custom study. With regular charts, it works fine. We provide it the datetime of a bar and scrolls so that bar is the last visible bar on the chart. When we use this method on TPO charts, the scrolling is off (the datetime we provide is based on the custom chart, not the underlying BaseData) I can send an example or provide more detail if needed. |
[2019-10-11 19:53:49] |
How can you have a custom chart and a TPO Profile Chart at the same time? That does not make sense.
[2019-10-12 02:34:54] |
onnb - Posts: 662 |
Its not a custom chart and a TPO Profile Chart. Its a regular 1 min chart with TPO Profile Chart |
