Date/Time: Sun, 02 Feb 2025 21:57:50 +0000
uploading a file/chartbook
View Count: 884
[2019-10-10 21:33:39] |
User672082 - Posts: 62 |
Im trying to upload a file and followed the instructions and the attached pic is what opens up when I click help, account settings.
Screenshot_2.png / V - Attached On 2019-10-10 21:32:32 UTC - Size: 21.86 KB - 286 views Attachment Deleted. |
[2019-10-11 19:41:15] |
What is shown in the image you provided is that someone shared a file with you. That is unrelated to you wanting to share a file out. What process are you using to share a file? Have you checked with the other user whether they have received the file or not? Here is the documentation for sharing a file with another user: File Sharing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-11 19:42:00
