Date/Time: Wed, 05 Nov 2025 05:52:00 +0000
[User Discussion] - Bollinger Bands
View Count: 1619
| [2013-12-16 21:00:00] |
| stab123 - Posts: 2 |
I was wondering, in Sierra Charts, if there's a way to convert the data points from a chart into a table; so corresponding to the Date in the row, the Open would be in one column, High in another, Low in another, etc... This table would also include the values of any Studies open in the chart, like Bollinger Bands for instance. The differences in Bollinger Bands, ADX and SAR between platforms continues. Please see below for a 1-Oct-13 comparison: 1-Oct-13 6C Z-2013 Upper 20D Lower ADX +DMI -DMI SAR Firetip 0.9788 0.9659 0.9531 27.5 23 25.6 0.9780 Sierra 0.9788 0.9657 0.9525 24.187 26.442 17.191 0.9768 Ninja 0.9788 0.9660 0.9532 26.05 29.48 20.58 0.9763 I don't understand why these values are all different, except for Upper, considering they're all math formulas with the same input values. |
| [2013-12-27 07:57:06] |
Yes. This can be done by using the Spreadsheet study: http://www.sierrachart.com/index.php?l=doc/doc_StudiesSystemsAlerts.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
