Date/Time: Sun, 02 Feb 2025 21:45:11 +0000
bar Based AutoBacktesting
View Count: 609
[2019-10-10 20:17:36] |
maddy91 - Posts: 11 |
How to set date from which time should it start backtesting? How to define which bracket should be used for the test because whatever bracket i set only one default bracket is being used. |
[2019-10-11 22:17:38] |
For a bar based back test the only way to control the starting date is through the Chart Settings: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseDateRangeFromTo Regarding the second question if you are referring to Attached Orders make sure you have set them on the correct Trade Window: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-11 22:20:55
