Date/Time: Sun, 02 Feb 2025 20:33:32 +0000
Ask volume Bid volume difference text indicator
View Count: 1239
[2019-10-10 14:48:11]
GiovanniD - Posts: 41
is there an indicator very similar to "ASK VOLUME BID VOLUME DIFFERENCE TEXT" but which shows me the sum instead of the delta?
Otherwise, is it possible to have the code of the "ASK VOLUME BID VOLUME DIFFERENCE TEXT" indicator so that I can study it and make the indicator that I want?
Piero
imageSierra richiesta somma.jpg / V - Attached On 2019-10-10 14:46:57 UTC - Size: 127.95 KB - 420 views
[2019-10-10 18:34:57]
The sum is just simply the total volume for the bar and yes you can do that by using this study:
Study Subgraph Above/Below Bar as Text
And yes you can modify the code. It is available. Refer to:
How to Build an Advanced Custom Study from Source Code
Date Time Of Last Edit: 2019-10-10 18:35:23
