Date/Time: Fri, 25 Sep 2026 06:14:44 +0000
Signed up for Sierra Chart Exchange Data Feed -- data not flowing.
View Count: 919
[2019-10-10 14:14:57]
SC Support - Posts: 2104
Separate subscription for market depth updates not supported. FDXM0919-EUREX | 2019-10-10 20:56:16.714
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. | 2019-10-10 20:58:40.268
The message log has been sent to support. | 2019-10-10 20:58:40.268
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Connecting to IP: 46.4.97.203. | 2019-10-10 20:58:40.268
Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2019-10-10 20:58:42.924
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Shutdown started. Waiting for graceful close. | 2019-10-10 20:58:43.182
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. | 2019-10-10 20:58:43.384
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Closed. | 2019-10-10 20:58:43.384
The message log has been sent to support. | 2019-10-10 20:59:32.506
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2. | 2019-10-10 20:59:32.506
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Connecting to IP: 46.4.97.203. | 2019-10-10 20:59:32.506
Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2019-10-10 20:59:35.148
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-10-10 20:59:35.402
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-10-10 20:59:35.602
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed. | 2019-10-10 20:59:35.602
The message log has been sent to support. | 2019-10-10 21:02:39.952
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Creating socket. Using TLS 1.2. | 2019-10-10 21:02:39.953
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Connecting to IP: 46.4.97.203. | 2019-10-10 21:02:39.953
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Socket gracefully closed by remote side. | 2019-10-10 21:02:47.270
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-10-10 21:02:47.270
HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Closed. | 2019-10-10 21:02:47.270
Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2019-10-10 21:02:51.612
The message log has been sent to support. | 2019-10-10 21:03:36.262
HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (2) | Creating socket. Using TLS 1.2. | 2019-10-10 21:03:36.262
HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (2) | Connecting to IP: 46.4.97.203. | 2019-10-10 21:03:36.262
Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2019-10-10 21:03:39.782
HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (2) | Shutdown started. Waiting for graceful close. | 2019-10-10 21:03:40.026
HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (2) | Socket gracefully closed by remote side. | 2019-10-10 21:03:40.311
HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (2) | Closed. | 2019-10-10 21:03:40.311
The message log has been sent to support. | 2019-10-10 21:04:58.220
HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (2) | Creating socket. Using TLS 1.2. | 2019-10-10 21:04:58.220
HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (2) | Connecting to IP: 46.4.97.203. | 2019-10-10 21:04:58.221
Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2019-10-10 21:05:04.597
HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (2) | Shutdown started. Waiting for graceful close. | 2019-10-10 21:05:04.843
HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (2) | Socket gracefully closed by remote side. | 2019-10-10 21:05:05.047
HTTPS connection ID:5 to www.sierrachart.com:443 for request ID:5 (2) | Closed. | 2019-10-10 21:05:05.047
[2019-10-10 14:56:53]
Resolved, user moving from Rithmic to the Sierra Chart Exchange Data Feed, he just needed to Translate Symbols
"If you have existing Chartbooks with futures symbols that match another supported Data or Trading service, then to automatically translate those symbols, open a Chartbook and select Edit >> Translate Symbols to Current Service."
Date Time Of Last Edit: 2019-10-10 15:09:25
