Date/Time: Wed, 23 Sep 2026 02:23:33 +0000
conexión cuenta fondeada
View Count: 1009
| [2019-10-10 13:50:30] |
| EDUAR FELIPE RUBIO HERNANDEZ - Posts: 1 |
Por favor me podrían indicar el costo de la licencia para conectar mi cuenta financiada por MES Capital. requiero tanto el costo de la licencia de la plataforma como el procedimiento para el pago y conexión, agradezco también si cuentan con una línea telefónica de soporte gracias. |
| [2019-10-11 14:06:42] |
| John - SC Support - Posts: 47980 |
The cost will be 26 USD per month. Follow these instructions to add usage time to your Sierra Chart account: 1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Login with your Sierra Chart Account Name and Password. 2. Choose the particular Service Package that you want to automatically renew and press the "Update" button. 3. Add sufficient credit to your Services Balance using any of the available payment options: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For further information, refer to: Sierra Chart Purchase and License Information: Renewing Access ------------------------------------ Support is done through this Support forum, or for account information there is the Account Support Tickets which is private. You will find the information on support here: Support and Contact - Support Options: Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-11 19:50:03
