Date/Time: Sun, 02 Feb 2025 20:46:08 +0000
CME E-Micro Charts
View Count: 1087
[2019-10-09 14:30:42] |
User196614 - Posts: 17 |
Hello, I can access the E- mini charts, but I can not access the E-micro charts on sierra charts. I can not find the symbol. Am I doing something wrong? Or is it not included with my service package? Thanks
[2019-10-09 18:02:33] |
We see you are using TD Ameritrade so we need to set these up. Not sure why that was not done earlier. However, first we have one question. Are you using any stock data from Ameritrade or are you just using it to verify you have a funded trading account to access the CME data through the Sierra Chart Exchange Data Feed? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-09 19:15:47] |
I don’t quite get the question so I will try to answer it the best way I can. I do have access to stock data and futures data through td ameritrade. I don’t use stock data with Sierra charts often. And yes Ameritrade is my broker and I am using it to get CME data through Sierra charts. I hope I answered correctly, what must I do? |
[2019-10-09 19:47:30] |
The most reliable thing to do is the follow the instructions here and use the SC Data-All Services service and just connect to TD Ameritrade once a month: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees (Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-09 19:48:29
