Date/Time: Wed, 12 Mar 2025 05:14:05 +0000
Draw Style to Write to Value Scale
View Count: 944
[2019-10-08 23:18:54] |
ILIM KIRGIZ - Posts: 187 |
I need to write a custom value at Value Scale. Is there a way or draw style to do so? This value is calculated by my custom study. Example: At 1.0000 price level I want to print red-backgrounded 20 value at value scale. Value label option shows 1.0000 but I want to print 20. Thanks. |
[2019-10-09 08:10:52] |
You can do it with this Draw Style: Chart Studies: Custom Value At Y (ACSIL: DRAWSTYLE_CUSTOM_VALUE_AT_Y) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-09 08:12:13
